Create Features in mobile geodatabase
1703
09-14-2021 04:49 AM
JérômeDuckers
I generated a ".geodatabase" with ArcMap (Export runtime content).
When I try with my code to add new Features, I receive an exception, the canEdit property is set as False  😞
Is it a way to insert new data in an empty geodatabase or it's mandatory to download data as offline data ?
Jérôme.
JérômeDuckers
I found this documentation :  export runtime content
Include feature and tabular data for read-only reference—Include all of the feature layers, tables, and relationship classes from the current map in the ArcGIS Runtime content. These layers will be read-only in your ArcGIS Runtime SDK-based app
Is it an another way to make an empty geodatabase and write new features in a table ?
MichaelBranscomb
Esri Frequent Contributor
Hi
With ArcGIS Pro (2.7 or later) you can create a new mobile geodatabase and add tables to that geodatabase then use the current ArcGIS Runtime 100.12 release to create/edit features in those tables. For more information see Mobile geodatabases and Read and edit standalone mobile geodatabases.
Would you like to use the ArcGIS Runtime API to create a new empty mobile geodatabase and create a new table, including defining the table schema?
Thanks
