Create a MultiLayerPointSymbol from SVG
1292
12-23-2024 11:59 AM
KarenRobine1
I'm using the RenderMultilayerSymbols.xaml.cs sample to create a MultiLayerPointSymbol. The AddPointGraphicsWithMarkerSymbols method uses the following example:
Geometry vectorElementGeometry = Geometry.FromJson("{\"rings\":[[[0.0,2.5],[2.5,0.0],[0.0,-2.5],[-2.5,0.0],[0.0,2.5]]]}");
However, I have an SVG Path I want to convert.  The path format is the following:
M16,3.5c-4.142,0-7.5,3.358-7.5,7.5c0,4.143,7.5,18.121,7.5,18.121S23.5,15.143,23.5,11C23.5,6.858,20.143,3.5,16,3.5z M16,14.584c-1.979,0-3.584-1.604-3.584-3.584S14.021,7.416,16,7.416S19.584,9.021,19.584,11S17.979,14.584,16,14.584z
In the past, you could convert SVG to Geometry using esriSMSPath (JavaScript). But not sure how to get my SVG format to Geometry? (FYI: The Path format represents a Map Pin icon..
PreetiMaske
ArcGIS Maps SDK for Native apps do not support SVG symbols. One possible alternative is to use this online tool to convert SVG to CIM https://utility.arcgisonline.com/arcgis/rest/services/Utilities/Symbols/SymbolServer/generateSymbol
Once you get CIM json you can directly create a symbol by passing CIM json to Symbol.FromJson()
https://developers.arcgis.com/net/api-reference/api/net/Esri.ArcGISRuntime/Esri.ArcGISRuntime.Symbol...
Hope this helps!
PreetiMaske
Hope this helps!
KarenRobine1
Perfect!!! Thank  you. Exactly what I needed.
