Could not load ArcGis Runtime(RuntimeCoreNet200_3.dll)
310
03-05-2024 08:52 AM
ofirrosner
New Contributor III
Hello i have a WPF application that was running with esri version 200.0 and net version 6.0
After we upgraded to net version 8 and esri version 200.3 im getting the following exception (after calling ArcGitRuntimeEnviroment.Initialize()):
Could not load ArcGis Runtime(RuntimeCoreNet200_3.dll) or one of it dependencies Ensure "Microsoft Visual C++ 2015-2022 Redistributable" is installed with inner exception : Unable to load DLL "RuntimeCoreNet200_3.dll"  or one of it dependencies: the specified module could not be found(0x8007007E)
And when i checked the AcGisRuntime200.3 folder all i see the resources folder(the .dll file seems to be missing)
I have tried the following solutions Solution 1  Solution 2
im using the following nugets
Esri.ArcGISRuntime.Hydography 200.3
Esri.ArcGISRuntime.WPF 200.3
Esri.ArcGISRuntime 200.3
window version 1809(OS build 17763.5458)
dotMorten_esri
Esri Notable Contributor
First thing to note is we require minimum Windows build 19044 in 200.3 (19041+ SDK).
Could you share what you have in your csproj file? Are you overriding runtime identifiers or Platform/PlatformTarget in that project?
If you use our project templates and create an ArcGIS WPF project, does that work and how does it differ from your project?
ofirrosner
New Contributor III
when i use the project template is working fine
i the only think(?) that is different the ".deps.json" is different, in my project the relevant dlls are missing from there(my project is a class library project)
Also in my project i have the following
<TargetFramework>net8.0-windows10.0.19041.0</TargetFramework>
<CopyLocalLockFileAssemblies>true</CopyLocalLockFileAssemblies>
<SupportedOSPlatformVersion>10.0.19041.0</SupportedOSPlatformVersion>
<AppendTargetFrameworkToOutputPath>false</AppendTargetFrameworkToOutputPath>
<AppendRuntimeIndentifierToOutputPath>false</AppendRuntimeIndentifierToOutputPath>
when i copied the above to the template project it didnt affected the result(worked fine)
