Change Elevation Source at runtime
2095
05-31-2023 05:42 AM
FlorianKowalsky
Is it possible to Change the ElevationSource at runtime?
I have two elevation Files (File1.tif and File2.tif) and i want to switch them.
MyScene.BaseSurface.ElevationSources.Clear());
if(file1)
	elevationSource = new RasterElevationSource(new List<string> { @"C:\File1.tif" });
else
	elevationSource = new RasterElevationSource(new List<string> { @"C:\File2.tif" });
elevationSource.LoadAsync();
MyScene.BaseSurface.ElevationSources.Add(elevationSource);
But if i switch, the Elevation sources seemed to be merged.
FlorianKowalsky
Thanks
Yes it works
This Code Works:
RasterElevationSource elevationSource = null;
if (isFile1)
else
Surface surface = new Surface();
surface.ElevationSources.Add(elevationSource);
await elevationSource.LoadAsync();
await surface.LoadAsync();
MyScene.BaseSurface = surface;
KoushikHajra
Hello @FlorianKowalsky
Thank you for reaching out to us with your question. You should be able to do it, except that you found a bug. I've logged an internal bug for it.
As a workaround, you can create and set (on the scene) a new baseSurface object every time, with the desired elevation source. Hopefully, that'll get you going in the meantime. Please let us know if you run into any further issues.
Thank you!
Koushik
FlorianKowalsky
Thanks
Yes it works
This Code Works:
if (isFile1)
else
KoushikHajra
That's great to see! If you have any further questions, please reach out.
