can ArcGIS Pro use cartographic representation
9725
13
08-04-2017 08:50 AM
MikkelHylden
We have a client that uses a cartographic representation to show some objects at an offset from where the geometry is.  This is done in ArcMap with the cartographic representation, but does not appear to work the same way in ArcGIS Pro (for publishing using the Runtime 100.1) for consumption on mobile devices.
Does anyone know if there is a workaround for this?
TimLangner
In the section on drawing layers with repsentations it has the following:
Representation symbology
The symbol model of ArcGIS Pro supports representation rules and can be combined with attribute-driven symbology to achieve cartographic outcomes with field-based representation overrides.
https://pro.arcgis.com/en/pro-app/help/mapping/layer-properties/draw-layers-with-representations.htm...https://pro.arcgis.com/en/pro-app/help/mapping/layer-properties/attribute-driven-symbology.htm
By saying the symbology model of ArcGIS Pro supports representation rules I assume they mean it supports the just display of them rather than modification. It looked at the attribute driven symbology options [Attribute-driven symbology—ArcGIS Pro | ArcGIS Desktop ] and they don't include offsetting lines.
by Anonymous User
Not applicable
Hi there! I need to offset lines. I have searched and not found any answers. Does anyone have an idea of how to do this in Pro? I was doing it in ArcMap. @KoryKramer ? thank you.
KoryKramer
Esri Esteemed Contributor
Have you tried to add a symbol layer (stroke) and apply an offset effect?
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/symbol-effects.htm
That's if you want to show the original geometry as well as the offset stroke.  Otherwise, you could just apply an offset effect on the single stroke symbol.
Does that help?
by Anonymous User
Not applicable
@KoryKramer  that's what I needed! thank you!!
