Basemap and layers are displayed only on the second run
908
05-22-2020 05:38 AM
MassimoMazzanti
I'am developing a .NET C# Android app, that start with a SplahAcitivity that calls the MainActivity module.
In the MainAcitivity I load a MapView component, inside a LinearLayout, declared in Main.xml,
The App compiles correctly, but at first run (in both debug and release version) the basemap and a feature layer are not displayed. The MapView area is completely empty (light blue color).
All the other times I run the application the basemap and the feature layer are displayed correctly.
I have tried to modify the code in various ways but without any positive results.
Do you have any ideas?
A piece of Main.xml:
<Esri.ArcGISRuntime.UI.Controls.MapView
       android:id="@+id/MyMapView"
       android:layout_width="match_parent"
       android:layout_height="0dp"
       android:layout_weight="1" />
Some lines of MainActivity.cs module are shown below:
public class MainActivity : AppCompatActivity
     MapViewModel _mapViewModel = new MapViewModel();
     MapView _mapView;
     protected override void OnCreate(Bundle bundle)
          base.OnCreate(bundle);
          SetContentView(Resource.Layout.Main);
          Initialize();
     private void Initialize()
          _mapView = FindViewById<MapView>(Resource.Id.MyMapView);
          _mapView.Map = _mapViewModel.Map;
          Esri.ArcGISRuntime.Mapping.Map myMap = new Esri.ArcGISRuntime.Mapping.Map(Basemap.CreateStreets());
         Envelope initialLocation = new Envelope(720000.0, 4942000.0, 1940000.0, 5900000.0,   SpatialReferences.WebMercator);
         myMap.InitialViewpoint = new Viewpoint(initialLocation);
   // Assign the map to the MapView
         _mapView.Map = myMap;
And this is the MapViewModel class declared in MapViewModel.cs
public class MapViewModel : INotifyPropertyChanged
     public MapViewModel()
     private Esri.ArcGISRuntime.Mapping.Map _map = new   Esri.ArcGISRuntime.Mapping.Map(Basemap.CreateStreets());
     public Esri.ArcGISRuntime.Mapping.Map Map
          get { return _map; }
          set { _map = value; OnPropertyChanged(); }
     protected void OnPropertyChanged([CallerMemberName] string propertyName = null)
          var propertyChangedHandler = PropertyChanged;
          if (propertyChangedHandler != null)
               propertyChangedHandler(this, new PropertyChangedEventArgs(propertyName));
     public event PropertyChangedEventHandler PropertyChanged;
Many thanks.
Best Regards
Massimo
