ArcGISRuntime - how to disable multi-select feature in the map
704
01-30-2025 09:31 AM
mallynaihabi
only want to allow single select feature in the map.
Thanks.
dotMorten_esri
Esri Notable Contributor
There is no select built into the map. Any selection is done with your own code, so you can in that code clear selection before selecting a new feature.
