ArcGISFeature.Attributes.Count is Much Lower than Expected
1550
05-30-2018 01:00 PM
TheKenerson
Newbie question of the day. I am writing a simple data editor using Xamarin Forms .Here is my issue: In my sample, when I access a selected feature in my feature service, I get a count of 4 for my feature service and I am expecting a count of 49.
The Count is displayed using the ArcGIS Feature.Attributes.Count Property.
So I can display and edit the attributes, but only a few of them.
I have tried accessing other feature services from AGOL, and their counts are way off too. Its generally about 10% of the total number of attributes.
I think the data is okay as I can access/display/edit the same feature service in a webapp using REST with the JavaScript API I just cannot access the data in the .NET Runtime Xamarin Forms Application.
Anybody else come across this behavior?
dotMorten_esri
Esri Notable Contributor
Did you load the feature first? By default only a minimum set of attributes needed for rendering is requested from the server so you won't get the network overhead of downloading a bunch of attributes you might not ever see. Once you identify a feature and want to display it in the UI, you should "load" it first so that all the data is included:
if(feature is ILoadable)
    await ((ILoadable)feature).LoadAsync();
dotMorten_esri
TheKenerson
Thank you. That was what i was missing. I'm new to the .NET API and i didn't know about it. Here is what i did and how i checked it. Maybe its helpful for somebody else.
public async Task LoadAsync_site(ArcGISFeature _feature)
Feature = _feature;
await Feature.LoadAsync();
//if the featurewas loaded successfully, you can see all attributes. Below is a test
if (_Feature.LoadStatus == Esri.ArcGISRuntime.LoadStatus.Loaded)
var A_value = Feature.GetAttributeValue("field_A");
var B_value = Feature.GetAttributeValue("field_B");
var C_value = Feature.GetAttributeValue("Field_C");
dotMorten_esri
I'm glad it worked out for you.
You don't really need the LoadStatus check. It's guaranteed to have succeeded - otherwise it would throw (so you might want to use try/catch instead)
