ArcGIS Runtime support for 'plugin datasource'
749
05-27-2022 09:56 AM
MattEsri
Does the new Runtime support 'the Plugin Datasource' concept (e.g., for .NET)?  I know the older ArcEngine Runtime (circa 2005) used to support it for C++.  Looking to source the ESRI map inside our desktop product with a non-ESRI datamodel and was hoping to implement ESRI Plugin Datasource to achieve this.
MichaelBranscomb
Esri Frequent Contributor
ArcGIS Runtime doesn't share the same Plugin Datasource model as ArcGIS Engine but supports many data/layer types and provides layers/overlays that can be used to render other content (GraphicsOverlay and FeatureCollectionTable).
Can you share any more information about the data format you need to support?
