ArcGIS Runtime: application crash when changing parent of MapView in WPF
4341
01-05-2016 04:40 AM
nirzur
I'm developing with ArcGIS Runtime SDK for dotNet 10.2.6.
(Environment: Win7 64bit, .net 4.5.2, compiled for x86, WPF project)
When I change the parent element (e.g. Grid) of the MapView in my project, the application sometimes just crashes with no exception or message. This happens after just a few switches between parents.
Is this a known bug ?
Any workaround ?
This is the error I see in the Windows Event Viewer:
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f7ce6
Exception code: 0xc0000005
Fault offset: 0x00011703
Faulting process id: 0x1ac4
Faulting application start time: 0x01d147a199237ca7
Faulting module path: C:\Program Files (x86)\ArcGIS SDKs\DotNet10.2.6\WindowsDesktop\bin\arcgisruntime10.2.6\client32\MSVCR120.dll
IanHogan
Were you able to find a solution to this? We have the exact same issue.
