Application freezes without exception
6267
6
08-28-2015 11:31 AM
TércyoStorck1
Hi. I’m developing a Windows Store Application and i got an issue. When i go back from the maps page after loading some layers from my .geodatabase (offline map). My Application freezes without exception. Anyone knows what's going on?
var layers = await esriUtil.GetlayersAsync(mapa);
mpvwBase.Map.Layers = layers;
LoadFlyoutIdentify(layers);
mpvwBase.Map.Layers.Insert(0, esriUtil.GetBasemap(mapa));
AnttiKajanus1
Thanks for reporting this, I have created bug issue for this.
AnttiKajanus1
Could you create simple solution that reproduces the issue?
cheers,
Antti
TércyoStorck1
Hi Antti,
Thank you for your prompt answer!
Yesterday while I performed  some tests, I discovered that the reason for the problem, but I not know how can solve.
When I enable a Label in any Layer of my map, always when I close an try open the map page again the application freezes.
If you want to analyze the code, its available to download on the link bellow:
Size 172MB (with sdk 10.2.6)
http://www.isgconsultoria.com.br/downloads/SampleBugTest.zip
Size 20MB(without sdk 10.2.6)
http://www.isgconsultoria.com.br/downloads/SampleBugTestWithoutPackage.zip
AnttiKajanus1
I tested the SampleBugTestWithoutPackage solution and couldn't reproduce any freezing. Could you tell me exact steps to get it occurring. I tried to navigate back and forth with and without labelling.
What computer setup you are using? Are you testing this on device or simulator?
TércyoStorck1
i'm tested on Surface and Dell Latitude. Both i got the same result.
Bellow i made two movies, showing the issue. And i repeated the process some times to get the issue, but some times that occurred on the first time i navegate back.
http://www.isgconsultoria.com.br/downloads/Freeze1.zip
http://www.isgconsultoria.com.br/downloads/Freeze2.zip
P.S: i'm using Windows 8.1 in both devices (WindowsRT for surface, ofcourse)
AnttiKajanus1
Thanks, I got the issue visible now. We will investigate what's going on with the labels.
AnttiKajanus1
