Application crashes randomly when updating Kml Layer
3697
09-03-2015 12:45 PM
JasonTrinidad1
I have a piece of code that updates a KML overlay often. Some times, at random, my application crashes after replacing the KML layer from my Scene. I do not get an error message, not does it let me debug it, so I suspect is somewhere in the ArcGis code. Is this the correct way to update a KML layer?
string id = objId + "Overlay";
System.IO.File.WriteAllText(_tempFilePath + @"\" + id + ".kml", kmlString);
var sourceUri = new Uri(_tempFilePath + @"\" + id + ".kml"); //I receive KML as a string, so I save as a file to get an URI
if (MySceneView.Scene.Layers[id] == null) //first time adding the layer
     var kmlLayer = new KmlLayer(sourceUri);
     kmlLayer.ID = id;
     kmlLayer.Opacity = _alpha;
     MySceneView.Scene.Layers.Add(kmlLayer);
     return id;
  else //Update the layer
     for(int i = MySceneView.Scene.Layers.Count - 1; i >= 0; i--)//for each layer
        if (MySceneView.Scene.Layers.ID == id) //find the matching ID
           kmlLayer.ID = id;
           MySceneView.Scene.Layers = kmlLayer; //repalce the layer with the updated one
           return id;
return "";
MichaelBranscomb
Esri Frequent Contributor
What happens if you modify the code to remove the existing KMLLayer from the Scene and set it to null then insert the new KMLLayer at the original index?
Cheers
Mike
JasonTrinidad1
If I remove the existing layer, I can't then set it to null, since its removed from the collection. If I just remove the layer and add a new one, it also crashes randomly.
