Add two layers to MapView control from same feature class
1580
05-27-2024 02:57 PM
Labels (2)
SusanPaplanus
I need to display upto 3 separate views of feature class that is located inside of a mobile geodatabase on a MapView.   The feature class/dataset needs to be displayed on three separate layers, which each layer will be using a different field that is symbolized (in this case to show fire, vegetation, and drought conditions).   I can add the first layer using:
featureLayer = new Esri.ArcGISRuntime.Mapping.FeatureLayer(Workspace.GetGeodatabaseFeatureTable(ActualFeatureClassName)
I create a classbreaks renderer, and then add the layer to the map :
Dispatcher.Invoke(() => MainMapView.Map.OperationalLayers.Add(myLayer));
and it adds ok.
When I try to create a new second layer using the same command, I get an error, "Object is already owned: Already Owned".
So the user may create one, two, or three layers (but it could be more in the future).  Is there any way to handle the case where we need to have more than one layer to be displayed off of the same feature dataset/feature class.
Susan
GKmieliauskas
You need to create new layer from scratch. I have modified ArcGIS Maps SDK sample to work without Already Owner fail. Code below:
            #region FeatureLayer
            // Get the full path for the mobile geodatabase.
            string geodatabasePath = DataManager.GetDataFolder("e12b54ea799f4606a2712157cf9f6e41", "ContingentValuesBirdNests.geodatabase");
            // Load the geodatabase.
            Geodatabase geodatabase = await Geodatabase.OpenAsync(geodatabasePath);
            // Load the Geodatabase, GeodatabaseFeatureTable and the ContingentValuesDefinition.
            // Get the 'BirdNests' geodatabase feature table from the mobile geodatabase.
            _geodatabaseFeatureTable = geodatabase.GetGeodatabaseFeatureTable("BirdNests");
            // Asynchronously load the 'BirdNests' geodatabase feature table.
            await _geodatabaseFeatureTable.LoadAsync();
            // Asynchronously load the contingent values definition.
            await _geodatabaseFeatureTable.ContingentValuesDefinition.LoadAsync();
            // Create a FeatureLayer based on the GeoDatabaseFeatureTable.
            FeatureLayer nestLayer = new FeatureLayer(_geodatabaseFeatureTable);
            // Add the FeatureLayer to the OperationalLayers.
            MyMapView.Map.OperationalLayers.Add(nestLayer);
            try
                Geodatabase geodatabase1 = await Geodatabase.OpenAsync(geodatabasePath);
                var table = geodatabase1.GetGeodatabaseFeatureTable("BirdNests");
                FeatureLayer nestLayer1 = new FeatureLayer(table);
                MyMapView.Map.OperationalLayers.Add(nestLayer1);
            catch (Exception ex)
                throw;
            #endregion FeatureLayer
GKmieliauskas
            try
                throw;
SusanPaplanus
Thank you very much for your assistance.  I was able to modify this example to get exactly what I wanted.   I really appreciate your help.
Susan
