Hello,
we've been having issues with our application crashing while in prolonged use (5~10 hours running) with no clear reason or pattern to allow for reliable reproducibility.
The application processes a lot of data at a time to display icons on the map as individual graphic overlays that would be rendered out on the map.
Exception information from the Event Viewer:
Application: Application.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at RuntimeCoreNet.GeneratedWrappers.CoreSymbolLayer.CoreRT_SymbolLayer_destroy(IntPtr, IntPtr ByRef)
at RuntimeCoreNet.GeneratedWrappers.CoreWrapperBase.PrivateDestroyHandle(Boolean)
at RuntimeCoreNet.GeneratedWrappers.CoreWrapperBase.Finalize()
Faulting application name: Application.exe, version: 2.35.0.0, time stamp: 0xf224efad
Faulting module name: MSVCP140.dll, version: 14.28.29910.0, time stamp: 0x602478ba
Exception code: 0xc0000005
Fault offset: 0x0000000000012df7
Faulting process id: 0x9a4
Faulting application start time: 0x01d8dd27c3b0ed12
Faulting application path: C:\Program Files\Project\Application.exe
Faulting module path: C:\WINDOWS\SYSTEM32\MSVCP140.dll
Report Id: 052b505e-d017-439b-8df6-6a4fe6536579
Faulting package full name:
Faulting package-relative application ID:
We've been trying to recreate this but there doesn't seem to be any consistent way to reproduce this, but we think this might be related to adding symbols calls using CompositeSymbol.
We've checked to see if this issue may have been resolved, would updating the library help?
Lukasz.
