Reading Layer results in COM Component Fail with 10.6 DLLs
660
07-27-2018 11:19 AM
EmanuelRamalho
I'm having an issue upgrading from 10.5 to 10.6 libraries. When I try to get the layer information from a layer file it aborts. All I've done was to replace 10.5 with the 10.6 DLLs and this is what I get when I try to access the Workspace:
Error HRESULT E_FAIL has been returned from a call to a COM component.
StackTrace: at ESRI.ArcGIS.Geodatabase.IDataset.get_Workspace()
I have a licensed ArcGIS Server 10.6 installed on the same box and I am initializing the license successfully in the code, however it is failing when I try to access a layer file (I've tried layers from 10.2, 10.5 and 10.6 and this was working previously). Am I missing something in the new DLLs? All I'm trying to do is:
var layerFile = new LayerFileClass();
layerFile.Open(m_filename);
var oLayer = layerFile.Layer;
var oDataLayer = oLayer as IDataLayer;
var oDataset = oDataLayer as IDataset;
if (oDataset == null) return;
var oWorkspace = oDataset.Workspace;
Thanks!
