Importing Web Appbuilder into .Net Core
1607
08-05-2020 02:35 PM
NovicaJosifovski
I am trying to import a Web Appbuilder app into my existing .net core web application. So far, I created a folder in wwwroot, called WebAppBuilder.
All the content from the Web Appbuilder app, I moved to this folder. Then I moved the following files to wwwroot/js
They were originally in the Web AppBuilder folder.
I also added a controller with a view and copied the body from index.html to the view.
    ViewData["Title"] = "Index";
<h1>Index</h1>
<!DOCTYPE HTML>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
    <meta name="format-detection" content="telephone=no">
    <meta http-equiv="X-UA-Compatible" content="IE=EDGE" />
    <title>ArcGIS Web Application</title>
    <link rel="shortcut icon" href="images/shortcut.ico">
    <!--[if IE 8]>
      <link rel="stylesheet" type="text/css"  href="jimu.js/css/jimu-ie.css" />
      <![endif]-->
    <style type="text/css">
            box-sizing: border-box;
        body,
        html {
            width: 100%;
            height: 100%;
            margin: 0;
            padding: 0;
            overflow: hidden;
        #main-loading {
            width: 100%;
            height: 100%;
            text-align: center;
            overflow: hidden;
            #main-loading #ie-note {
                position: absolute;
                top: 0;
                bottom: 0;
                left: 0;
                right: 0;
                margin: auto;
                width: 586px;
                height: 253px;
                background-image: url('images/notes.png');
                padding: 0 30px 40px 30px;
                font-size: 14px;
                color: #596679;
        #ie-note .hint-title {
            height: 40px;
            line-height: 48px;
            text-align: left;
            font-weight: bold;
        #ie-note .hint-img {
            background-image: url('images/hint.png');
            background-position: left;
            padding-left: 40px;
            margin-top: 20px;
            background-repeat: no-repeat;
            height: 30px;
            text-align: left;
            line-height: 30px;
            font-weight: bold;
        #ie-note span {
            display: block;
            line-height: 14px;
        #main-page {
            display: none;
            width: 100%;
            height: 100%;
            position: relative;
        #jimu-layout-manager {
            width: 100%;
            height: 100%;
            position: absolute;
    </style>
    <link rel="stylesheet" type="text/css" href="configs/loading/loading.css" />
    <script>
     * This is the function you can modify to customize the loading page
     * This function will be invoked when one resource is loaded.
    // var progress;
    // function loadingCallback(url, i, count) {
    //      var loading = document.getElementById('main-loading-bar');
    //      loading.setAttribute('title', url);
    //   if(!progress){
    //     progress = document.createElement('div');
    //     progress.setAttribute('class', 'loading-progress');
    //     loading.appendChild(progress);
    //   progress.style.width = (((i - 1)/count) * 100) + '%';
    </script>
</head>
<body class="claro jimu-main-font">
    <div id="main-loading">
        <!-- This is section you can modify to customize the loading page -->
        <div id="app-loading"></div>
        <div id="loading-gif"></div>
        <!-- //////////////////    END    ////////////////////////////// -->
        <div id="ie-note" style="display:none;">
            <div class="hint-title">Error</div>
            <div class="hint-img">Your browser is currently not supported.</div>
            <p class="hint-text">
                <span>
                    Please note that creating presentations is not supported in Internet Explorer versions 6, 7.
                </span>
                <br>
                <span>
                    We recommend upgrading to the latest Internet Explorer, Google Chrome, or Firefox.
                </span>
                <br>
                <span>
                    If you are using IE 8 or later, make sure you turn off "Compatibility View".
                </span>
            </p>
        </div>
    </div>
    <div id="main-page">
        <a role="link" id="trapLinkNode" tabindex="0">Trap Link Node</a>
        <div id="jimu-layout-manager"></div>
        <div id="skipContainer"></div>
    </div>
    <script src="~/js/env.js"></script>
    <script src="~/js/init.js"></script>
    <script src="~/js/simpleLoader.js"></script>
</body>
</html>
The app builds successfully and runs, but when I navigate to the view I get errors in console.
Would anyone have any idea why it can't find /load the resources? Also, why does it say loadResources is not defined?
GeoRig
@NovicaJosifovski You were able to find out a solution to your problem? Let me know as I am also in a similar situation.
