How to disable popup in the Search widget using popupEnabled in JavaScript API 4.4?
1957
08-04-2017 02:57 PM
FernandoVara
Hello,
I am trying to work with the Search widget example in ArcGIS JavaScript API 4.4 (Search Widget | ArcGIS API for JavaScript 4.4 ) and I am not able to disable the popup with popupEnabled property. Using version 4.3 of the API is working. Is this a bug?
The example in the documentation that i am trying to use is:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Search Widget - 4.4</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
<script src="https://js.arcgis.com/4.4/"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/widgets/Search",
"dojo/domReady!"
], function(
Map,
SceneView,
Search) {
var map = new Map({
basemap: "satellite",
ground: "world-elevation"
var view = new SceneView({
scale: 123456789,
container: "viewDiv",
map: map
var searchWidget = new Search({
view: view,
popupEnabled: false
// Add the search widget to the very top left corner of the view
view.ui.add(searchWidget, {
position: "top-left",
index: 0
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
MohamedShefeek
 Make enableInfoWindow: false   In Search
var search = new Search({
map: map,
enableLabel: true,
enableInfoWindow: false,
popupEnabled: false
}, "search");
