Export data using arcgis sketch tool javascript api
1874
11-05-2019 11:36 AM
Gauravkhatri
How can I export data using Sketch Tool Widget I see it creates a feature but I want to extract the points it's covering.
The reason I want to use this instead of "Features by Geometry" because I can create multiple polygon, rectangle, circle at a time.
I want to be able to select that data/points its covering on a csv layer and extract/export them as CSV.
Below code just creates the tool and you can also see in the image that it selected a feature but that is not getting selected from a csv reference it's on the map
 const sketch = new Sketch({
      layer: layer,
      view: view
view.ui.add(sketch"top-right");
CodyCastle
Were you able to figure out how to export the sketches?
