Exporting in Survey123: Survey answer change in Excell
1252
03-13-2018 12:28 PM
AndrewRosales
Hello,
I created a Survey123 survey for a group of students to use collecting data on plant biodiversity. The app worked well in the field and the results look great on the Survey123 website. However, when I export the data-set from the website in Excel, some of the fields are changed. For example, I have some drop-down menus and when exported show "option2, option11, option21" as opposed to the view on the webpage of the plant name.
I used the webdesign feature (drag & drop) and didn't build the survey in excel. Is there a way to change this in my survey or on the back-end?
Here are some examples: Survey123 Web View
Exported i Excel View:
I did notice that the plant coverage buttons are square, but the drop-down choices for the plants are circles. I was wondering if that is part of the problem.
Thanks in advance,
Andrew
SMauri
  1. Download your data in Geodatabase format
  2. import in ArcMap
  3. export Tabel to Excel with this tool: Table To Excel - Help | ArcGIS Desktop wtih this option "Use_domain_and_subtype_description" set to True
Or
  1. Import feature layer hosted of your Survey123 in ArcGIS Pro
  2. export Tabel to Excel with this tool: Table To Excel - Help | ArcGIS Pro with this option "Use_domain_and_subtype_description" set to True
Cheers
Stefano
