Native AI-Assisted Python Code Generation from Geoprocessing History
147
a month ago
Status: Open
PadamPaudel
Summary
I would like ArcGIS Pro to provide a built-in feature that automatically converts interactive geoprocessing workflows into clean, executable Python scripts using ArcPy.
Current Workflow
Many GIS users perform spatial analyses through the ArcGIS Pro graphical interface. Although the Geoprocessing History records executed tools, transforming an entire workflow into a reusable, well-structured Python script still requires considerable manual effort. Users often need to reorganize tool calls, define variables, handle paths, and improve readability before the script can be reused or shared.
Proposed Feature
Introduce an "Generate Python Workflow" option that analyzes the complete geoprocessing history of a project and automatically produces a structured ArcPy script.
The generated script could:
  • Combine all executed tools into a logical workflow.
  • Replace hard-coded paths with configurable variables.
  • Detect repeated operations and organize them into loops when appropriate.
  • Add concise comments explaining each processing step.
  • Validate input and output datasets before execution.
  • Export the workflow as a standalone Python (.py) file or Jupyter Notebook.
  • Optionally provide recommendations for improving performance, such as using in-memory workspaces or parallel processing where applicable.
Benefits
This feature would:
  • Reduce the learning curve for GIS professionals transitioning to Python.
  • Encourage reproducible and transparent geospatial analyses.
  • Save time when automating repetitive workflows.
  • Improve collaboration by generating standardized, readable scripts.
  • Support education by helping users understand how ArcPy corresponds to GUI-based operations.
Example Use Case
A user performs a workflow involving clipping, buffering, intersecting, spatial joining, raster extraction, and map generation entirely through the ArcGIS Pro interface. With one click, ArcGIS Pro generates a clean, documented ArcPy script that reproduces the complete workflow and is ready for modification, scheduling, or integration into larger automation pipelines.
This capability would bridge interactive GIS analysis and Python automation while promoting reproducible geospatial workflows across research, industry, and education.
