Editing in Map Series Pages individually
880
11-18-2025 01:07 PM
Status: Open
JosianneGuay
Map series are wonderful when you have a lot of layouts to prepare, it is quite a time server. Unfortunately, one size doesn't fit all in certain situations. It would be nice once the Map Series Pages are created, if we could individually edit some of the pages. I feel that without this option, we get to produce average maps, not the BEST maps.
3 Comments
AdrianWelsh
Josianne, can you describe more about editing the individual pages? You can jump to individual pages in your map series and edit the data within that page alone when you activate the map from the layout.
JosianneGuay
Just wish that I could fix the map extent on all of the pages at once and export as a PDF. If I fix one page, move to a second one and then come back to the first one, extent goes back to the original. So it means that I need to export 1 single page at a time instead of the whole document.
JamesPoeschel
Which map series type are you using? You should be able to set different extents for each page using the output of the map index geoprocessing tool. Unless you mean you want to freeze each page so you can have different elements in each map or have multiple map frames per page.
