Value list missing model tools exported to python scripts?
1169
01-30-2020 11:28 PM
AyokunleAdebisi1
Hello community, I built a tool with builder, however, i exported it python script to add more functionalities, but the script only shows the parameters but the list of values under each parameters is not displayed. I need it to display because that is where I want to set functionalities or is there any other way to edit such? please let me know ASAP. Thanks
This what my script looks like
import arcpy
# Script arguments
Sitename = arcpy.GetParameterAsText(0)
if Sitename == '#' or not Sitename:
    Sitename = "All locations" # provide a default value if unspecified
Category = arcpy.GetParameterAsText(1)
if Category == '#' or not Category:
    Category = "Gänse" # provide a default value if unspecified
Species = arcpy.GetParameterAsText(2)
if Species == '#' or not Species:
    Species = "Graugans" # provide a default value if unspecified
Month = arcpy.GetParameterAsText(3)
if Month == '#' or not Month:
    Month = "September" # provide a default value if unspecified
Start_Year = arcpy.GetParameterAsText(4)
if Start_Year == '#' or not Start_Year:
    Start_Year = "2000" # provide a default value if unspecified
End_Year = arcpy.GetParameterAsText(5)
if End_Year == '#' or not End_Year:
    End_Year = "2006" # provide a default value if unspecified
That is my value list on the right.
DuncanHornby
MVP Notable Contributor
When you created your original tool you had to add your list values to a value list property of the parameter when you set up the tool interface. This is part of the interface and not the code behind the model, so will not export.
You basically have to do it again when you set up the script tool interface.
