Greetings,
First time posting on here; have looked extensively online and have unfortunately found nothing on the topic.
I'm new to using model builder, but I was able to set up a location allocation model that iterates through the number of facilities to find. The model is working fine and providing all the outputs in the format I need except for one: a layer file (.lyr) for each iterated network analysis layer. While the layer files are saving to the folder I've indicated (and for all iterations) when I drag them into ArcMap only the demand lines sublayer is/can be displayed. The rest of the sublayers (e.g. demand point, facilities, point barriers, etc.) are present and have data in their attribute tables, however I can't get them to display (even when going through their symbology settings).
Below is a zoomed-in screen capture of the output handling (right side of first image). In addition to attempting to save to layer file, I am also saving each of the sublayers (facilities, demand lines, and demand points) to separate folders. The collect values is for displaying them to ArcMap. As I mentioned, everything is working except for trying to get the layer files to display. The layer files are not imperative, but it would be nice to get them working because it's so much easier to drag them into ArcMap for quick viewing. Just as a side note, the model is white (i.e. not ready to run) because I've set it up to allow the user to input all relevant data.
Thanks in advance for any help that may come my way.
Cheers!
