Using ModelBuilder not all fields in a feature class are included in the output
3652
05-13-2015 07:14 AM
SindileBidla
I have created a model in ModelBuilder which does the following;
     uses the feature classes iterator (the feature classes have varrying numbe of fields)
     uses the make feature layer tool
     uses select by location tool
     feature class to feature class tool (this writes the selected feature classes into a feature dataset)
For reason I do not understand not all the fields of a feature class are created in the last step.
I have also attached the model as a graphic
JeffWard
Honored Contributor
From your image, it looks like Feature Class to Feature Class didn't run (no grey drop shadow under the tool).
I have often looked at the output of a previous run from a model I have created thinking this run gave the same results.
Do you have overwrite output set in your environment?
Are you running the model from ArcMap, and do you have fields hidden in your layer?
Jeff Ward
Summit County, Utah
