Hi
I am trying to perform a summary on a poly line dataset. This data contains an attribute for the year the section was laid and the diameter of the section. I want to sum the length of these sections group them by both year and band. However I want to group the bands and years e.g year laid 2000-2010 and diameter 150-300 mm. I have created a model which does what I want but I was wondering if there was an easier way to carry out this task. I was also wondering if there was a way to modify the model so that the user could can the year bands and diameters in a table of spreadsheet. I am new to the model builder. Maybe there is a better way to do what I am trying to do. See attached images.
Ciaran
You can make an model input variable a multi value list, one variable for each of your classify variables.
Then you can use that multi value list in Calculate Field, inside the code block splitting it into a Python list with “;”.split().
Here is a Calculate Field expression I came up with that seems to do what you want. Dan Patterson numpy is pretty handy!
<SPAN class="comment token"># Calculate Field expression, specifying to update field "class"</SPAN> <SPAN class="comment token"># Source field is the name of the field we want to classify</SPAN> classify<SPAN class="punctuation token">(</SPAN>!<SPAN class="operator token">%</SPAN>Source field<SPAN class="operator token">%</SPAN>!<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Code block </SPAN> <SPAN class="comment token"># breaks is a multivalue model variable I created of type Double</SPAN> <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np breaks <SPAN class="operator token">=</SPAN> sorted<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>float<SPAN class="punctuation token">(</SPAN>k<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> k <SPAN class="keyword token">in</SPAN> <SPAN class="string token">"%breaks%"</SPAN><SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> breaklab <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"<{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>breaks<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> breaklab <SPAN class="operator token">+=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"{} up to {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>breaks<SPAN class="punctuation token">[</SPAN>k<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> breaks<SPAN class="punctuation token">[</SPAN>k<SPAN class="operator token">+</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> k <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN>len<SPAN class="punctuation token">(</SPAN>breaks<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> breaklab <SPAN class="operator token">+=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">">={}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>breaks<SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> breaks <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>breaks<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">classify</SPAN><SPAN class="punctuation token">(</SPAN>vv<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> p <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>searchsorted<SPAN class="punctuation token">(</SPAN>breaks<SPAN class="punctuation token">,</SPAN> vv<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'right'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> breaklab<SPAN class="punctuation token">[</SPAN>p<SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Curtis,
Thanks for the information but i must be doing something stupid. I have tried to simplify this to test. So i created a new feature class with the same structure as your example and with the same names. When i try to run the model i get an error about value type. I have set the to type double. See attached images which will hopefulyl help.
Regards
I have got this working now thanks.
I didn't realise the coulmn that is being updated has to be of datatype text/string.
Thanks again
Hi @curtvprice
i know this is an old post but i am doing something similar, but instead of multivalue variable i am using Table of Values variable. and i need to split the variables so that i could use in them for field calculation.
I have posted a question here in communities would love to pick your brains on the topic
Hussain
