Use model builder to generate output file names
1465
12-28-2023 08:46 AM
JoshDawe
I am using Arcmap 10.8.2 to delineate watersheds and I have used model builder to automate my work.
Is it possible to generate the output file names as well? I have been trying to do this without any luck.
I need the file names to be as follows: 1-160_FDir.
The 1-160 is my structure number that the user will have to input. The "FDri" portion is the indicator for which raster it is.
I have no experience with phyton so any help would be appreciated.
BobBooth1
Hi Josh,
Have a look at inline variable substitution in ModelBuilder.
https://desktop.arcgis.com/en/arcmap/latest/analyze/modelbuilder/examples-of-inline-model-variable-s...
You can use those, for example, with an iterator, to create a set of file names.
Best,
Bob
