Tools error in model builder
3521
6
11-07-2017 07:00 AM
Briande_Vogel1
When I try to edit my model all the tools are turned white with only two of the four borders drawn.
I also can't select the tools anymore, see picture below. Anyone knows how to fix this?
Error Tool box in model builder
Briande_Vogel1
Thanks for looking in
It only happens in this model, I tried the save/reboot/reopen of the model and also saved it under a different name. None of it helped though.
I solved it by ctrl-a the whole model and pasted it into a new blank model and everything works fine again.
DanPatterson_Retired
details like arcmap version etc would help rule out issues already seen
Briande_Vogel1
Ah sorry! I am using Arcmap 10.4.1.
I can't find any specific bugs, but I would be concerned it occurred in all models and/or the view persisted after a save, a reboot and a reopen of the model
MichaelVolz
Esteemed Contributor
Did you have this model working in an earlier version of ArcMap?  If so, do you have the ability to still run the model there?
Briande_Vogel1
one of the great modelbuilder mysteries... I will add it to my list of recommendations
