Table Select Not Working
2819
6
04-16-2018 06:41 AM
JohnMcConalogue
I have created a Feature layer and I want to do a SQL select on the feature layer. To accomplish this I have converted the feature layer to a table using the Create Table tool. Now I am attempting to carry out a SQL select on that table using the Table Select tool.
The problem is that when I go to build the SQL expression, the fields contain no values and are blank, yet in the feature layer the fields contain values.
Tags (1)
DanPatterson_Retired
According to Table Select it supports
The input can be an INFO, dBASE, or geodatabase table, a feature class, table view, or VPF dataset.
Do you mean a feature layer ? or feature class?
JohnMcConalogue
It is a Feature Layer.
I am trying to select certain records from the feature layer, is there another way to do this without converting to a table?
Why not do it in_memory if you don't want to create a physical table on disk... you can dump it when you are done with it if you are doing this in a script or modelbuilder
JohnMcConalogue
doing in model builder but I havent  a clue about In_memory
John... http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/the-in-memory-workspace.ht...
It is like it exists... briefly, but use Delete when done to be safe
JohnMcConalogue
Thanks Dan
