Run a custom model via ArcPy fails
2061
12-15-2014 12:36 PM
JorgeVidinha
I'm trying to geocode a few address using a custom model created. When running the model via model builder all runs perfectly.
Also when running it via the embedded interactive python console in ArcCatalog using the following code it also runs smooth.
    >>> arcpy.ImportToolbox("C:\\Users\\jvidin\\AppData\\Roaming\\ESRI\\Desktop10.1\\ArcToolbox\\My Toolboxes\\usps_geocoder.tbx","geocoder")
    <module 'geocoder' (built-in)>
    >>> arcpy.geocoder_geocoder('01')
    <Result ''>
The problem occurs when trying to run it via IDE using the following code:
The model has one and only one exposed parameter and it is an inline parameter %<param>% used for outputs paths creation .
>it creates the output .gdb based on argument sbr and sets env.workspace to it. (works)
>than when it runs arcpy.geocoder2_geocoder(sbr), in egg. sbr = '01' it fails with:
**Process finished with exit code -1073741819 (0xC0000005)** not of much help.
Script below.
    def geocoder(sbr):
        try:
            fgdb = str(sbr) + '.gdb'
            path = "J:/Postal/Postal/99_Geocode/_results/"
            env.workspace = path+fgdb
            print env.workspace
            arcpy.CreateFileGDB_management(path, fgdb)
            arcpy.geocoder_geocoder(sbr)
        except Exception as e:
            print e.message
Really have not clue why it continues to fail, tried many things out of ideias. All the outputs of geocode_geocode() model are setted to same env.workspace created.
The geocode_geocode() model -> contains 2 composite locators that run one after other.
Thanks for support.
curtvprice
Suggest moving this discussion to Model Builder‌ where it will get more visibility.
curtvprice
You may want to try looking for the arcpy messages:
import arcpy
try:
except arcpy.ExecuteError:
    print(arcpy.GetMessages(0))
    print(e.message)
One thing to keep in mind is that in ArcCatalog any environment settings you set in the application will apply. When running from outside the application, you need to be careful to set those environment settings the way you want them (for example. env.overwriteOutput).
JorgeVidinha
Thanks Curtis,
     Did add the excepts mentioned but the script continues to fail with some complex report, i cant figure out.
About the environment settings i made a print of all them. I dont see anything that would cause the crashes in my knowledge . The env.overwriteOutput i think its not important since i'm always creating the .fgdb on the fly but even i added arcpy.overwriteOutput = True
See below the env's table.
newPrecision             : SINGLE
autoCommit               : 1000
XYResolution             : None
XYDomain                 : None
scratchWorkspace         : None
cartographicPartitions   : None
terrainMemoryUsage       : False
MTolerance               : None
compression              : LZ77
coincidentPoints         : MEAN
randomGenerator          : 0 ACM599
outputCoordinateSystem   : None
rasterStatistics         : STATISTICS 1 1
ZDomain                  : None
transferDomains          : False
resamplingMethod         : NEAREST@@
snapRaster               : None
projectCompare           : NONE
cartographicCoordinateSystem  : None
configKeyword            : None
outputZFlag              : Same As Input
qualifiedFieldNames      : True
tileSize                 : 128 128
parallelProcessingFactor : None
pyramid                  : PYRAMIDS -1 NEAREST DEFAULT 75 NO_SKIP
referenceScale           : None
extent                   : None
XYTolerance              : None
tinSaveVersion           : CURRENT
nodata                   : NONE
MDomain                  : None
spatialGrid1             : 0.0
cellSize                 : MAXOF
outputZValue             : None
outputMFlag              : Same As Input
geographicTransformations: None
spatialGrid2             : 0.0
ZResolution              : None
mask                     : None
spatialGrid3             : 0.0
maintainSpatialIndex     : False
workspace                : J:/Postal/Postal/99_Geocode/_results/01.gdb
MResolution              : None
derivedPrecision         : HIGHEST
ZTolerance               : None
scratchGDB               : C:\Users\jvidin\AppData\Local\Temp\2\scratch.gdb
scratchFolder            : C:\Users\jvidin\AppData\Local\Temp\2\scratch
packageWorkspace         : J:/Postal/Postal/99_Geocode/_results/01.gdb
addOutputsToMap          : True
fail log:
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or assembly 'GpMetadataFunctions, Version=10.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified.
File name: 'GpMetadataFunctions, Version=10.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86'
   at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
   at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
   at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
   at System.Reflection.Assembly.Load(String assemblyString)
   at GetManagedType(Char* _assembly, Char* _path, Char* _className)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
curtvprice
I just got this error today from 10.2.2 in the middle of running a large intensive process. I wasn't using model builder, this was from a Python script.
Since some metadata functions are only 32-bit, I tried working around this by running the script with 32 bit python. Maybe you could try that:
c:\Python27\ArcGIS10.2\python.exe myscript.py
