Renaming Toolset within ArcGIS Pro
3302
11-05-2015 08:02 AM
JaredScott
There is probably a simple answer to this, but I can't seem to find it.  I've created a model within ArcGIS Pro.  I have a toolset within this model, however I can find no way of renaming it within ArcGIS Pro.  I've tried using ArcCatalog, but those changes won't take with this model.
Thanks in advance for any help.
DanPatterson_Retired
I am not sure if this is where the renaming is done​ but give it shot
JaredScott
thanks for the response - I've tried going to that location - that will allow you to rename the model itself within the properties, however there is no such interface I can find for the toolsets within the model.
BlytheSpendlove1
Hi Jared, I assume you have already found an answer or a work-around, given that this question is from 2015, but just in case, with ArcGIS Pro 2.1.x, you can right click on a toolset and rename it.
