Reference .mxd parameter in ArcGIS Pro's modelbuilder?
1459
08-08-2016 06:51 AM
JohnSolly1
I am trying to save the following python script as a tool to be incorporated into modelbuilder within Pro:
mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")
arcpy.mapping.ExportToPNG(mxd, r"C:\Project\Output\Project.png")
It works in ArcMap but I'm not sure how to do it in Pro since it does not use .mxd files.
How can I access the map document in Pro and run a tool that traditionally uses an .mxd?
DanPatterson_Retired
Things are a bit different in PRO... did you read these sections?
Migrating from arcpy.mapping to ArcGIS Pro—ArcPy | ArcGIS for Desktop
Guidelines for arcpy.mp—ArcPy | ArcGIS for Desktop
You are going to have to work with the new project format ... aka... *.aprx
Cross-pollination isn't going to work... you are going to have to get the project into a pro format
JohnSolly1
Gotcha. Thanks!
