Output not connecting as input in GIS model builder
4721
12-02-2017 01:52 AM
AkhilChhibber1
GIS Modelbuilder
As seen in the image, I am trying to connect "Output Dataset" i.a result of merge of 2 shapefiles as input in the CLIP tool.
As you can see in the image(in the red highlighted area), input option is not coming when I am trying to connect "Output Dataset" with CLIP.
What should I do?????????
AbdullahAnter
Honored Contributor
Just you need to add Select Data ( model builder tool) after the output of Merge tool.
see the following picture:
DanPatterson_Retired
you haven't specified any parameters yet, check some of the visuals in the tutorial
http://desktop.arcgis.com/en/arcmap/latest/analyze/modelbuilder/creating-tool-with-modelbuilder-tuto...
Madanbhurati1
You have to make feature layer  of output dataset, You can use "make feature layer" GP Tool from data management tools. than connect that feature layer dataset to a clipping feature class.
AbdullahAnter
Honored Contributor
AkhilChhibber1
Thanks a lot it worked for me
curtvprice
I have used Select Data before to unpack feature classes out of a feature dataset. Here you have used this tool to tag a model element of unspecified datatype (Merge is not able to do this because it can take many types of inputs) to the data type of the model element on disk. I have done this "tagging" before with Calculate Value but this is niftier. Nice trick!!
