Output disappearing after Add Field in Model Builder
1278
09-17-2018 09:02 AM
deleted-user-XBIblHRrwSU9
Hi guys,
I'm creating a Model Builder model, which works fine until i'm starting to Add Fields to my shapefile. For some reason, after this step my shp completely disappears from folders, however if i delete this last step of the model, the model runs and shp is visible again. Does anyone know why is this happening and how it could be fixed?
I am working in ArcMap 10.2
Any advice/info is much appreciated!
Thank you,
Simona
MichaelVolz
Esteemed Contributor
Could you try using a file geodatabase feature class instead of a shapefile and see if the model works better in that scenario?
