[ModelBuilder] Output names
3249
08-27-2014 02:22 AM
FilipeTeixeira
Hey there,
I've this toolset used for a Quality Control on a final produt, wich is ran in different batches, in example:
PA2970
PA5000
PA4450
I was wondering if, by running it in different moments for the different batches, there's a way to have the outputs have their name ("SegLote") followed by the respective batch code, in example
SegLote2970
SegLote5000
SegLote4450
How could I do this?
Another question:
this toolset has 4 different models, wich I run each following the other 1-2-3-4. how do I make a script (or whatever) so I only run one thing and it gives me all the processes?
sorry for my english, hope you understand my doubts...
Cheers
JimCousins
Assuming you are working in modelbuilder, you can parse the name from the file, and use a calculate Value to create the string subset, and then use that as an inline variable to create the output filename. see attached model for visual explanation. Note I have attached the OutName as a precondition to running the buffer tool, so the Calculate Value bit has to run first.
Input is PA4450, the Parse Path extracts the name from the full path of the file. Calculate Value uses a simple bit of python to strip off the first 2 characters ("%InName%"[2:] ). Then I use the OutName variable along with the SegLote string to create the output filename. I have attached a graphic of the model and  the model as a toolbox if you want to see the values.
Regarding running your 3 processes, you can nest them in a single model. If they need to run in sequence, use precondition connections to dictate which order they execute.
Best Regards,
Jim
