ModelBuilder - Delete fields in exported files from KMZ
4131
10-03-2014 08:01 AM
CraigPrisland1
Hello all,
I have a ModelBuilder question that I hope to get some assistance with.  I am using the KML to Layer tool export KMZ files out to feature classes which I am easily able to do.  I created a quick model for the user to do so using various input parameters (i.e. where to save the layer file and geodatabase, what to name the output).  My question is how would I be able to automatically delete certain fields out of these outputted feature classes right away when I am exporting this file?  What I have currently done as a work around is create a separate model that the user can use to delete the fields after they run the first model that exports them.  I am looking to find a way combine this into one model.  As a side note, the field names will always be the same in the outputted point, line, and polygons feature classes.
Any assistance would be greatly appreciated.  Thank you in advance!
