Modelbuilder: Calculating value on added field
1398
05-29-2012 01:29 PM
JohnWarden
I have a county level database of population statistics and am creating a model that will add a new field to the database, pop_density (population density). After adding the new field, I want the model to calculate the population density by dividing population by area. Both population and area already exist in my database.
I insert the Calculate Field tool and specify as the input for Calculate Field the output file from the Add Field tool. When I go to input the expression for pop_density in Calculate Field, it only shows me the Pop-Density field I just added, and it does not show me any of the pre-existing fields in my database. How do I use the Calculate Field tool when one of the variables in the calculation formula does not exist until the model has been run?
EadieKaltenbacher
Those fields should be there. First try saving and closing your model, them re-opening it. Next, check if you have done any previous operations that might have removed them, such as Buffer? If so, you may need to perform a join to get your original fields back.
