Model Runs But Outputs Aren't There
9920
10
05-05-2016 09:50 AM
ChrisHolmes
Good day everyone,
I have the following model:
Which seems to run fine (based on the output to the dialog display):
But even though the output shows that the "Copy Features" tool created "site_polygon2", I cannot find it in Catalog (even after refresh):
I would expect it to show up under "site_polygon".
If I look in windows explorer in the data_for_item.gdb folder, I do see the following lock file:
I am stumped as to why I can't find site_polygon2. The help is always appreciated.
Chris
NIC135pitteduCarter
Writing because I just had a similar problem, but solved it; I ran my model once before deciding to rename it, but I couldn't find the renamed file anywhere, so I ended up realizing it was under an autogenerated name from the first run...
Tags (1)
