model crashes at the buffering section
1391
11-21-2019 04:25 PM
BRADLEYMAYGER
I have a model that keep crashingmodel layout at the buffer stage, any ideas?
the files are large
MichaelVolz
Esteemed Contributor
Can you provide screenshots of error message?
What versión of ArcMap are you running?
Where are you processing data?
BRADLEYMAYGER
I didn't get to see any error as it totally shut arcmap down  10.6.1  data was being processed across our network
curtvprice
If you suspect a network issue, try copying it to a local location and buffering it local.
MichaelVolz
I am working in ArcMap 10.7.1, but I recently had a script that worked fine over the network through many ArcMap versions (10.3.x to 10.5.x), but now has to be run where the GIS processing occurs locally on the Windows 2016 Server server as it failed the majority of the time when processing the data to a file gdb over the network.  The script works every time when run locally in ArcMap 10.7.1.
I would also suggest exporting to python so you can enable error handling to see what errors are thrown up.
DuncanHornby
MVP Notable Contributor
Try running the model in ArcGIS Pro. If your datasets are large and complex you may be hitting some 32bit limitation in ArcMap.
