Model Builder wont let me save
2601
06-12-2020 08:02 AM
Lebowski
Hello All,
I have been working with Model Builder in Pro for quite some time a bit but today I am trying to make a simple 'Raster Clip Model' and it will not let me save the check box in the "Use Input Features for Clipping Geometry:Boolen" and I also cannot rearrange the steps from the properties tab. First, the word 'Parameter' is underlined in red (not usually the case) and  there is a asterisk next to step I want to rearrange, when I hover over it says "Parameter Name and DataType are required." I am not seeing any options to resolve this error. I am sure its something relatively simple I am missing but any help and/or suggestions would be appreciated!
SiqiLi
by Esri Contributor
Hi Chad, the Clip Raster tool Use Input Features for Clipping Geometry parameter is dependent on the Output Extend parameter. Once the value for Output Extend parameter is provided, the changes for Use Input Features for Clipping Geometry can be saved successfully. Hope this helps.
