Model Builder tool parameter inputs will not apply to the model in 2.6
1542
08-31-2020 01:35 PM
ShelleySchulte1
I am having issues running my model and a GP tool in Pro 2.6.  When I set all my parameters within the model builder view and run it in the MB view it is fine.  But when I try to run it as a GP tool in that toolbox it reverts back to the previously entered parameters from the model run.  I can't figure out what I'm doing wrong!  Is this a bug?
DuncanHornby
MVP Notable Contributor
Have you exposed the inputs as parameters so you change them when you run your model as a tool?
JJ_Reyes
@ShelleySchulte1 - did you figure this out? I'm having a similar problem. When I run the Geoprocessing tool, the input is completely ignored. Runs fine in Model Builder itself!
