Model builder iterations problem (Txt files to .lyr files)
5786
9
11-12-2014 04:07 AM
SprumontFrancois
Hello everybody,
I have a folder with multiple text files containing X Y data. I would like to transform each of these txt files into a .lyr file.
I thought I could work with Model Builder but I think I have problem using "Files iterator".
For each txt file, I would like to obtain one .lyr file but by running the below model I obtain a single file (and not several one).
Could you please help me ?
Pieter_Geertvan_den_Beukel
The Iterate Files tool has an output format (file) that can not be connected to the Make XY Event Layer tool. Use the Iterate Tables tool instead.
See NewModel in attached toolbox.
RaymondHuang1
Looking at your model, your make xy event tool will only run once. Your make xy event tool should take in the output of the iterator as an input(solid arrow) instead of a precondition (dotted arrow) like what it is now. Can you try to change this and let me know if it works for you?
SprumontFrancois
Hello,
Thank you for your reply.
I don't know why but when I try to connect the green box "File.txt" and the tool "make xy event layer" it is always a dashed line (precondition) and not a solid one.
perhaps I have to fix something with the name of the Input / output...I don't know what's going wrong
RaymondHuang1
Attach a screenshot of your textfile content format please?
ChrisDonohue__GISP
The naming may become an issue if the resulting layers are being placed in a File Geodatabase.
Additional rules
Chris Donohue, GISP
SprumontFrancois
More precision on the data ? Ok !
The text files I want to transform in .lyr files (or shapefiles...) are composed of 3 columns: X,Y and time.
Here is an overview:
Y,X,TIME
51.21646,5.08759,1900-01-01 10:37:27
51.21643,5.08798,1900-01-01 10:37:32
51.21653,5.0882,1900-01-01 10:37:37
51.2166,5.08844,1900-01-01 10:37:42
51.21664,5.0886,1900-01-01 10:37:47
51.21664,5.0886,1900-01-01 10:37:52
What I don't understand is that when I develop a model for one single text file, it works. Thus, I think my issue is related to the "File iterator tool".
RaymondHuang1
I tried to quickly create a similar model and it works on my side.
​Can you share your toolbox containing your model please?
SprumontFrancois
Ok, no problem.
In the attached file, the toolbox related to the picture I posted previously.
Let me be clearer: In a folder called Folder1, I have multiple text files structured like this:
Y,X,TIME
I would like to use model builder to automate the process of "Make XY event layer" and "save to layer file".
I thought I could use the file iterator tool to run the model on all the text files in folder 1.
Thanks for your help !  I appreciate a lot...
SprumontFrancois
Great, Thank you !
I thought I had to use the "File iterator"...I don't know why I never tried this "Table iterator"...
Thank you for your help !
