Model builder giving a 000438: Overlay not polygon error when clipping features
3010
10-03-2023 08:02 PM
AndrewHankinson
I have created a simple model that should run the fishnet tool creating a fishnet grid (polyline) and fishnet labels (points) for a specified area of interest. The model should then go into clipping both these features against the area of interest.
However, when I run the model it fails on the clipping tool, giving a 000438 error. But I am clipping a polyline and point features against a polygon feature, equally I can run the clip features tool against the fishnet outputs following a more manual approach.
I must be missing something but for the life of me can't see what, this is my first time trying to create a model though.
Any help would be appreciated, I've attached a screenshot of the model for reference.
DanPatterson
MVP Esteemed Contributor
It isn't possible from you image to determine what featureclass you are using as the clipping featureclass to ensure that it is a polygon type
... sort of retired...
AndrewHankinson
Hi Dan,
Thanks for replying.
I've attached a screenshot the site boundary polygon I was using to clip the point and polyline features.
I've also tried this model with a different site boundary polygon within a different project and get the same error message.
DanPatterson
not sure you can clip with a PolygonZ featureclass.  Try a copy of the featureclass omitting the Z component
AndrewHankinson
Hi Dan,
Thanks for the suggestion, I created a new polygon AOI without a Z tolerance and I get the same error message.
It's quite strange as if I run the individual tools using the same layers everything works fine
