Model Builder Freezes When I click Verify
5589
11
03-03-2016 02:29 AM
MarkYoung3
For some reason model builder just hangs when I click verify on a simple query within query builder on the final select process below. The query is:   table name.FIELDNAME is null
If I verify without running the first two processes it says there is an error with the expression. If I run the first two processes then click verify it hangs and I have to kill ArcMap and try again.
Tags (1)
JacobTodd1
Hi Mark,
What version of ArcMap are you using?
MarkYoung3
JacobTodd1
Is this a new issue? When did this begin occurring?
MarkYoung3
I don't use model builder that often but as far as I know it used to work OK
Thanks
Mark
JacobTodd1
Below are some suggestions:
  1. Try using model builder in a different map document.
  2. Reset your Normal.mxt by changing it's name to Normal_old.mxt then try to either open and existing map document or a new one to see if this resolves your issue. The path to the Normal.mxt is below:
       (C:\Users\<your username>\AppData\Roaming\ESRI\Desktop10.3\ArcMap\Templates\Normal.mxt)
MarkYoung3
Cleared normal template and tried again but it just hangs.
Thanks
Mark
DuncanHornby
MVP Notable Contributor
If the error message is saying that it's with the expression then I guess that is the problem!
  • Update your question to show the expression that is being used. You seemed to have given us a generic example rather than the actual expression.
  • What's the data source formats? Are you joining a dBase to an ArcSDE?
  • Confirm that your join actually worked, do that outside model builder.
MarkYoung3
That was the sql query (apart from table name and field name is aliased) - I just want to select null values in a field. Unfortunately there is no error message, it just hangs then I have to Kill ArcMap
Thanks
Mark
DuncanHornby
Your query has a space in it between table and name, that would be invalid
Personally and far from me to tell you how to do your analysis but a dataset called "table name" and a field called "fieldname" are not very descriptive! What metadata are you going to write about these and it is not very helpful for others if you intend to pass this data onto a client. It's akin to receiving a dataset simply called export_output7.shp. Export of what?
