Missing output variables in model builder
2441
07-13-2017 12:32 AM
TerryBeutel
Can someone please tell me why when I drag tools into model builder they have an attached output variable. But if I create a tool in model builder that uses the same esri tool and drag that tool into model builder I see only the tool and not the output variable? The picture attached has an example, but I got the same result from a much more complicated tool I built that I am having difficulty iterating and I am wondering if this might be an issue.
DanPatterson_Retired
You can expose the parameters as inputs
http://desktop.arcgis.com/en/arcmap/latest/analyze/modelbuilder/exposing-tool-parameters-as-variable... and make variables from parameters
http://desktop.arcgis.com/en/arcmap/latest/analyze/modelbuilder/creating-model-parameter.htm
have you tried to do this manually since I suspect with the tool inputs, the input and output is automatic, where with a model it might be assumed that they have already been preset
TerryBeutel
Thanks Dan. Making the output feature class a parameter did the job. Much appreciated!
glad it worked
