Iterator: Select(analysis) tool
1042
03-31-2017 07:30 AM
GregoriusIvaniddo
Hi All,
I am trying to make a model which would iterate the select (analysis) tool.
Basically, I have a feature class with more than 10,000 points. These point have different Z values (height), with the field name is "POINT_Z".
So, i want to export these points into different feature class by dividing them based on the Z values.
Without using model builder, I will need to manually select these points using the select(analysis) tool.
this is the SQL script to select the features that have height between 32 and 33
(POINT_Z >=32) AND (POINT_Z <33)
This process of using select(analysis) tool is repeated with different height range, but I was wondering whether there is a way to iterate this process.
The lowest and highest values of the POINT_Z is 32.355 and 69.804 respectively. Thus, the intended output is 38 different feature classes alltogether (FC with Z value between 32-33, FC with Z value between 33-34, so on and so forth)
Can anybody help me on this problem?
Thank you in advance!
 model builder; #iterator
curtvprice
MVP Alum
Easiest way is to add a field, calculate a value using the expression Int([POINT_Z]) and then use the Iterate Field Values tool to select each group of points.
