I am trying to pull the point feature from 12 different geodatabases and then merge them all into a new point file containing all the data. When I run the process it returns the data from the last GDB file in the output dataset but does not include the other 11. I am sure I am missing something simple. I would appreciate any help. Thank youScreenshot 2023-11-08 174204.png
any help.
I believe I figured out how to make it work. Using the Collect Value tool did the trick. I am a total hack at AGP so I am not going to explain how it works. This post: https://community.esri.com/t5/modelbuilder-questions/merge-all-iteration-output-to-single-output-in/.... got me on track.
Below is my updated tool.
