Iterating through a Geodatabase using a script to identify feature class names
916
07-10-2017 01:37 PM
MattDeveney
I am trying to create layers from feature classes in a geodatabase and ultimately applying standard symbology at the end. To do this I started a model with an iterator running through each feature class, and with a script, checking the name of each feature class and seeing if it matches one of the feature class names on the right side of the model.  I am stuck at incorporating the script into the model.  Any help would be appreciated.  My started script and model are below.
def namechk(int):
   if str Name == "Survey_Calculated_Boundary_Monument":
      return 1
   else:
      return 0
