Iterate Files
4649
9
01-04-2017 09:28 PM
GotreGotrewyan
I have a folder with many raster files in .nc format. I want to build a model to do some proccessing on each raster and finally export an excel file for each raster with the same name. The model screen shot is
The model
when I run the model its stopping with no result as picture shows:
Result
but the model work fine for one raster file.
Is something wrong with iterator files? and how can I fix it?
please help me
Tags (1)
DanPatterson_Retired
Do .nc files appear as datasets in Catalog? if so, then they may be being skipped Iterate Files—Help | ArcGIS Desktop I think you have to use the iterator on Reading netCDF data using geoprocessing tools—Help | ArcGIS Desktop rather than on the files directly
GotreGotrewyan
No, the .nc files does not appear in ArcCatalog. As you see I already imported the netCDF geoprocessing tool (make netCDF raster layer) in the model. I'm quite not sure about what to do. Can you explain how to fix it?
Sorry for my weak English and thank you  for answering
sorry... missed that tool in the model... I can't find anything specific to modelbuilder, only the basis from a solution using python https://community.esri.com/message/535067
GotreGotrewyan
Thank you Mr Patterson, I will try that and send feedback to you.
curtvprice
I highly recommend getting rid of the iterator in the model and getting it work for one dataset. Then add try adding the iterator once you have it working.
GotreGotrewyan
As I mentioned above(in the question), the model works fine for one dataset but any way thanks for answering.
curtvprice
Wasn't clear to me that that was what you meant (you can iterate on just one input too.
You may want to make the input file and name parameters put this model as a submodel of a another model that contains the iterator. This may avoid your validation problems.
GotreGotrewyan
I'm not sure what is your mean exactly!! Anyway I mean that if I remove the iterate file in the model and give it just one raster (nc format) file the whole process works good. Now I want to run this model for 5000 rasters. So I placed the 5000 rasters in one folder (folder name: "nc") and introduce it as a input. Now when I run the model the error comes up
I hope I'm clearly explained the issue.
the 'name' oval is connected to the export to excel oval.  you can't export a *nc file's name to excel.  look at the example of an iterator here Example of using an iterator in a model—Help | ArcGIS Desktop
