How to use Calculate Value for if then?
2112
05-07-2020 01:17 PM
WhitneyWeber
I have looked through the documentation for using Calculate Value to act as if then in Model Builder, but am not connecting the dots. I want to Get Count to determine the number of rows. And then use that with Calculate Value to return TRUE else FALSE. So, if Row Count>0, then TRUE, else FALSE. Then use a While to point to the appropriate next steps. But how do I connect the Row Count to the Calculate Value? Obviously I'm missing a step or have made this too complicated because this is not feasible as described.
Please advise!
Tags (1)
DavidPike
MVP Notable Contributor
I don't use model builder but I had a quick look. Something along the lines of (guessing the model builder syntax):
myfunc(%Row Count%)
def myfunc(input):
    return bool(input)
FC_Basson
Your row count can be done like this in Modelbuilder
with you Calculate Value expression like this
WhitneyWeber
I apologize for not replying sooner - that was very helpful and worked, but I required additional complexity which forced me to Python. I needed to take the leap regardless. Thank you for your response and help!
