How to select a raster from raster catalog by a selected point with a field that contains the raster name
4870
05-31-2016 02:40 AM
RolandGliba
Hy!
I have a managed raster catalog and its raster's names are contained in a field in a point feature class. I use the select layer by location tool with an in memory point to get the point and then I need something to get this value to the select layer by attribute tool. Can anyone help me? thank you
Roland
FC_Basson
You can set the Expression value in the Select Layer By Attribute tool by using the field value of the previous process with an inline variable:
MYFIELD = '%Value%'
Also make the Get Field Value result a precondition for your final select by attribute process.
RolandGliba
I did it, get field value is made as a precondition to the select layer by attributes, the model is running without any result so the problem is, either with the get field value process or with the expression.
FC_Basson
This is where you need to break your model down in parts and see what each process required inputs and results are.
curtvprice
You aren't seeing any thing in the message dialog that gives you a clue?
One approach you may want to try is to use the Calculate Value tool to compose your SQL expression from the output of Get Field Value. Value would be a precondition to Calculate Value, which would use the expression:  r"MYFIELD = '%Value%'" with the datatype set to SQL expression. The SQL expression would then connect into your Select Layer By Attribute tool.
